Block Plugins from using Ctrl Shift I
Ctrl Shift I is used to open the Console which can be useful for all sorts of situations. There is however a popular plugin that keeps taking over the hotkey. This is leading to confusion when offering troubleshooting to less experienced users as you first need to troubleshoot why the console wont open.
Can Ctrl Shift I be simply blocked from being able to be mapped?
Identify that Console wont open. Go into Settings > Hotkeys > search for Iconize > delete the hotkey > recommence troubleshooting.
