Obsidian will suggest potential links in the backlink panel based on the current file name, but many times (at least in Chinese mode) you can’t find potential links if the file name is long or specific, I think it could be more flexible.
Enhance the backlink panel :Be able to search a certain word
in the panel —> show result in the panel—> add a link (the link format can be [filename|word]
