Better Edit — a multi-feature editing toolbox for Obsidian: rich image arrangement, block drag and drop, slash commands, and more
Disclaimer
Community Directory: Link
Hi, I am Toby. I started using Obsidian because I love the fact that I can customize it to whatever I like. I stared use it as my main note taking app, but I felt a lot of frictions editing my notes, including creating a checkbox, moving lines around, and more importantly the image resizing and arrangement.
So I created Better Edit, that includes:
  1. Image Arrangement: resize, crop, alignment, image rows (with css flexbox), etc
  2. Block drag and drop: should work as you might expect. Clicking the handle shows options to delete, create copy, and turn into
  3. Slash commands: customizable commands, including inserting a template or execute an registered command
  4. Text styling: should just work as you might expect
  5. Emoji/symbol picker : should just work as you might expect
Note that the image feature is achieved by pure html/css. This means that your image edits stays even without the plugin turned on. Better Edit only help editing, it does not touch rendering. The html/css will be fully portable, to platforms that can render them. Note that some platforms like GitHub disable inline css fully, so the rendering does not work.
Some demos
Image edit and alignments
Image row with css flexbox
Customizable slash command
Blocks drag and drop
More Disclaimer
Just a disclaimer that AI tools are involved in the development. I do have JavaScript and frontend/backend backgrounds and have reviewed the codebase. I did spend a lot to time polishing all details but never felt enough, so I figure it’s a good idea to share this plugin with others and collect some feedbacks. I know adding all 5 features altogether is kind of ambitious. Any feedback or advices are welcome!
Thank you for you attention!
Toby Chen
Just wow ! I’m not a mouse guy but I could use this.
Hello there! First of all, this plug-in is awesome and very helpful. I just have a question. I’m not sure how to access the other menu, which has the “Wrap” option. Sorry if there is an obvious answer to this that I’m missing. Does it only work with image rows? I’m trying to get my text to wrap around images.
Hi there!
Sorry for the late reply. And unfortunately the image and text are still managed separately. So the image and text can’t work together, therefore there’s no wrap option for the text around an image.
I believe this is still doable in markdown, using some customized html to wrap the image and text together. However it’s not really a regular markdown thing in my opinion. I do still want to keep this plugin simple and only improve the markdown edit experience better, instead of recreating something new.
Please let me know what you think and share some more feedback for the plug-in if you have any!
Best,
Toby
