I keep a small vault just for the mobile games I test, and it has turned into a mess I don’t really know how to fix.
The setup: I have two phones I use for testing, an old Redmi Note 9 and a Poco F5, and for each game I make a note with three things - average FPS, how much battery drops in 30 minutes, and the highest temperature I can feel on the back. I made a template with those three as plain fields and a Dataview table on a dashboard page that pulls them all in.
The problem is entering the numbers. Typing them by hand after every session is slow enough that I skip it, and when I do keep up, the table gets wide because each game needs a row per device. I tried tags like fps-bad instead, but then I lose the actual numbers. I tried one note per device with a table inside, and now the device note and the game note duplicate each other, so I update one and forget the other.
Has anyone found something that stays fast to fill in and still lets you compare two devices for the same game? I’m on Obsidian 1.14 on Windows, mostly Dataview, and I’d rather not add another plugin if I can avoid it. Would also like to hear what didn’t work for you.
Since it’s consistently three tests on two devices, the most straightforward way might be to simply add to the game note a property for each test:
Redmi avg FPS:
Redmi batter drop:
Redmi high temp:
Poco avg FPS:
Poco batter drop:
Poco high temp:
With that, you could type in test results from a base without having to open the game note. And you can filter and group by device, test type, game, etc. There’s no separate testing note to manage.
If you don’t want to dedicate six whole properties to values the feel more like “breakout” properties, then you could instead use YAML mappings. Here’s one example:
Redmi tests:
- avg FPS:
- battery drop:
- high temp:
Poco tests:
- avg FPS:
- battery drop:
- high temp:
Bases (and Dataview) can parse those. Plugins like Nested Properties let you edit them in the Properties interface at the top of the note. Or just switch to Source mode to add the values.
Personally, I’d probably put them all into a single “device tests” property in the game note, so that over time, I could add devices and tests without interfering with or changing existing test documentation:
device tests:
- device: Redmi Note 9
avg FPS:
battery drop:
high temp:
- device: Poco F5
avg FPS:
battery drop:
high temp:
You could even add the test date. Or keep records of multiple tests on different days.
Thanks, this is helpful. I added the six properties to one game note and can now sort by device without opening anything. Do you keep the test date in the note name or as a property?
Update on my own question: I went with one note per device and a test_date property, then a Dataview table sorted by that. It’s less clever than a single database note, but I actually keep up with it, which was the real problem.
The thing I didn’t expect: filling in the frontmatter every session got old fast, so I now keep a template with everything prefilled except the two numbers that change.
Notes on the whole setup are here if anyone wants the template: my measurement notes
Small follow-up after a week with this: I stopped listing every device separately and now keep one note per build with a devices field, then pull the rows for whichever phone is in my hand.
What surprised me is how often I forget to update the date on those notes. Do you tag entries by device, or just link them from the daily note? That part still feels clunky.
