Hi,
I’m working on a plugin that adds the capability of rendering musicxml and mxl files inside of obsidian notes.
I managed to get the relevant span and replace it with a very basic version of the rendered sheet music. However, I have problems with getting the relevant files efficiently.
export default class MusicXmlPlugin extends Plugin {
async onload() {
try {
this.registerExtensions(
MUSICXML_FILE_EXTENSIONS,
VIEW_TYPE_MUSICXML
} catch (error) {
new Notice(
`File extensions ${MUSICXML_FILE_EXTENSIONS} had been registered by other plugin!`
this.registerMarkdownPostProcessor((element, context) => {
const elWithEmbedFiles =
element.querySelectorAll<HTMLElement>(".internal-embed");
// Is this the the best practice way of getting all spans with embed content?
const mxlFiles = app.vault.getFiles().filter((file) => {
for (const extension of MUSICXML_FILE_EXTENSIONS) {
if (file.extension === extension) return file;
// This is how I get the musicxml/mxl files from the vault.
// However, it seems inefficient to me since I only need to get the files of the currently opened note
for (let index = 0; index < elWithEmbedFiles.length; index++) {
const el = elWithEmbedFiles.item(index);
const src = el.getAttribute("src");
// Here I identify which embed sources exist in the note.
// For some reason if the embed file lives in a nested folder not the entire path is found in the src-attribute
// Only if 2 files with the same name exist the full path is found in the src-attribute
const isMusicXml =
src!.endsWith(".musicxml") || src!.endsWith(".mxl");
// For all embed files that are musicxml/mxl-files and have a src the rendering is initiated
if (isMusicXml && src) {
// This only works for files in the root directory
const srcFile = mxlFiles.find(element => element.name === src);
context.addChild(new RENDER_FUNCTION_CLASS_PLACEHOLDER(srcFile.path));
My questions can be found within the pasted code.
I’d appreciate any input as I’m totally new to plugin-development.
Thanks!
