Beginner Q - Properties: Created and Updated - How to make them appear on a note?
(Sorry if this is a super obvious issue).
I’m trying to add automatically created and updated properties to my notes. When I watch videos from other creators, these properties automatically populate.
However, they remain dd/mm/yyyy --:–:-- on my notes.
I also recently subscribed to Obsidian Sync.
googling, adding {{date}} to the yaml, looked through the forum.
Core Plugins “On”
backlinks, bases, bookmarks, canvas, command palette, daily note, file recovery, files, graph view, note composer, outgoing links, outline, page preview, properties view, quick switcher, search, sync, tags view, templates, word count.
Community plugins
calendar, dataview, excalidraw, nature language dates, omnisearch, pandoc plugin, pandoc reference list, paste url into selection, tag wrangler, tasks, zotero integration
For this to work you need to put it in a template. Then you can trigger the template in your notes (see the Help page about templates). You would want separate templates for Created and Modified dates, so you don’t overwrite the Created date.
I believe the Linter plugin also has a creation date feature. I don’t know if it also handles modified dates.
