Currently, Bases operates on a One Note = One Record paradigm. While this aligns perfectly with the atomic note philosophy, it creates significant friction for users who prefer to maintain centralized, flat logs (e.g., a single Movie Log.md with 100 movies listed, a Daily Journal.md with a bulleted list of daily tasks, or a Ledger.md of financial transactions).
Forcing these users to split a single, lightweight list into 100 separate Markdown files just to utilize the Table or Cards view adds unnecessary file bloat, complicates vault navigation, and breaks the user’s preferred data structure.
Introduce a new Source Type when creating or configuring a Base. In addition to “Folder” and “Tag,” add “File Blocks” or “Inline List.”
When a single file is selected as the source, the Base parser should treat individual Markdown elements within that file as the records.
Supported Inline Formats
- Bulleted / Task Lists with Inline Fields (Dataview-style)
The Base parses each list item as a row, reading inline metadata formatting (e.g., [Key:: Value]). - Standard Markdown Tables
The Base natively hooks into an existing Markdown table inside a note, providing the advanced filtering, sorting, and Card layout UI on top of raw pipe-separated text. - Frontmatter Arrays / Sub-properties
Alternatively, the Base could parse a structured YAML/TOML array within the note’s single front matter block.
Examples:
- The Matrix [genre:: Sci-Fi] [rating:: 5] [watched:: 2026-05-10]
- Inception [genre:: Sci-Fi] [rating:: 4] [watched:: 2026-06-01]
OR
movies:
- title: The Matrix
genre: Sci-Fi
rating: 5 - title: Inception
genre: Sci-Fi
rating: 4
UI/UX Implementation Details
The Setup Flow: When creating a Base, selecting “Source: Single File” prompts the user to select the parsing method (e.g., “Parse bullet points,” “Parse Markdown table,” or “Parse YAML array”).
Two-Way Editing (Crucial): If a user edits a property inside a Card or Table view, the Base edits the specific string or block line inside that single file, maintaining Obsidian’s commitment to live two-way data syncing.
The “Card Layout” Render: For a movie list inside one file, selecting the Cards View would instantly turn those 100 bullet points into 100 visual tiles, rendering inline image links as cover art.
