Bases - sorting a column after expanding width of other columns results in duplicate columnSize entries in YAML and causes Uncaught YAMLParseError: Map keys must be unique at line 22, column 5
Use the following base in the sandbox vault
  - type: table
    order:
      - file.name
      - count
      - formula.price
      - formula.percent
      - contexts
      - file.ctime
      - file.ext
    sort:
      - column: property.contexts
        direction: DESC
      - column: formula.price
        direction: DESC
      - column: formula.percent
        direction: DESC
Follow instructions in the GIF. Essentially, extend the right most column enough to create a horizontal scroll bar, then extend the second last column so that the last column goes out of visibility, then sort the third last column. This somehow results in duplicate columnSize entries in the YAML as shown in the stacktrace on the right side. If I go to the source view and remove this duplication, the base comes back.
base_sort_after_width_expansion_duplicate_bug_clean
Yes
No crash when sorting
Crash
Obsidian version: v1.9.1
Installer version: v1.7.7
Operating system: Windows 11 Home 10.0.26100
Catalyst license: insider
Insider build toggle: on
I don’t know if there is a second issue or not, but sometimes, this causes the whole base code to disappear, essentially corrupting the note.
Here is the first stack trace when this crash happens. This is from a second attempt after I recorded the GIF
app.js:1 Uncaught YAMLParseError: Map keys must be unique at line 22, column 5:
      file.ctime: 220
    columnSize:
    at constructor.onError (app.js:1:768265)
    at app.js:1:752692
    at iy (app.js:1:753701)
    at app.js:1:766193
    at dy (app.js:1:766737)
    at app.js:1:754292
    at iy (app.js:1:754423)
    at app.js:1:766193
    at app.js:1:753214
A post was merged into an existing topic: Embedded Bases Codeblocks: Code changes / corruption when dragging to resize columns
