Bases QoL - Default values for columns
I have many bases that could do with setting default values when adding a new entry.
A few examples of things I’d like to be able to do:
  • Setting a ‘date’ property to default to today’s data
  • Setting a 'number’ property to default to 0
  • Set a default value for a ‘list’ property
Adding and hooking up default properties to the ‘+ New’ button in bases would solve my problem
Or we could associate a template with the adding of an item in a base.
Adding properties manually every time I create a note
I agree.
For me, default property values is a better solution than using folder-triggered templates with the Templater plugin.
It would be nice to be able to define default values for either “All views” and “This view”, as is currently possible with Filters.
