Bases multi-select
I tried to select multiple files at once in a base I created, but I realized I couldn’t. If I have a large base with a large number of files, I figured we should be able to use multi-select on the different files within the bases, sort of like in Windows File Explorer. You can select multiple images, pictures, or video files. But here I can only select one file at a time.
I was thinking of a multi-select feature within bases. Where you can copy, cut, share or delete
The implementation: You can select multiple files at once within the base of your choice. If you enable a multi-select feature, each file should have like a sort of checkbox(blue and white is my preference, but you can also do standard purple and black obsidian theme).
Problems with implementation: If I delete multiple files with the base, should my other bases be affected be they all pull from the same source?
There is no workaround for this; you can only select one file at a time.
It would be awesome if bases could read thumbnails within images, files, or PDFs, and music (for cover view), so that when someone selects the file they want, then they could have the assurance that they are selecting the correct file. Because we have a problem if we are purely going by name, multiple files will have multiple similar names, etc.
At least with table view, is possible to select multiple notes (Table view - Obsidian Help).
+1 such a straight-forward feature, i cant believe it’s not already in
i’d like to see this feature improved as well. currently we can multi select only in table view by click dragging or holding shift, but can’t select individual entries by holding ctrl
