Bases loads slowly when loading images
  1. Create a new base
  2. Filter the base to contain lots of images (raw jpegs here, not notes with image property)
  3. Click on another note then back on the base
Did you follow the troubleshooting guide? Yes.
The base loads just as quickly as one with notes with image property.
The base takes multiple seconds to load
Obsidian version: v1.9.14
Installer version: v1.5.12
Operating system: Darwin Kernel Version 24.4.0: Fri Apr 11 18:32:43 PDT 2025; root:xnu-11417.101.15~117/RELEASE_ARM64_T8103 24.4.0
Plugins installed: 1
Plugins enabled: 0
In the same vault there also is a base that contains notes with an image property, this base loads almost instantly whereas the one which loads image files directly takes multiple seconds to load.
I am not sure I follow you and I can’t reproduce.
  1. Download and reinstall Obsidian.
  2. Create a vault (no themes, no plugins, etc) where the problem happens. Zip it, upload it somewhere and DM me a link.
