Apologies if this has been addressed elsewhere, but I couldn’t find my answer in the documentation or forum: Is it possible to give a program/script/AI access to the “rendered” output of a base?
I have a number of workflows in Dify (a low-code AI system) that allow me to interact with my Obsidian notes via the REST API plugin. It would be really helpful if I could give Dify access to the output of my bases to make the workflows more tailored to my vault. E.g. I have one base that serves as an “index” of context files for an LLM. It would be far simpler if Dify could read the list of file paths from the base (and then extract their content via the API for an LLM to use) rather than have to crawl the YAML in each note in the vault to find the relevant files.
I have tried accessing the files containing the bases directly, but this only shows the base code, not the “rendered” content. The same applies when using the API. I know that it’s possible to export a base to CSV, but this requires me to keep the index manually up-to-date.
I would be more than happy to use a script/plugin within Obsidian to periodically copy the rendered data from the bases into a dedicated note within the vault, but I haven’t yet found a way to do this. Any help would be appreciated.
Many thanks,
Michael
