Bases if-clauses turn Markdown Links into raw Strings
Code like “if(related, related, “else”)” does not forward the “related” property faithfully, but instead shows its markdown links as raw strings.
In an otherwise empty Sandbox Vault, create the following note (remove the escape character in the last row):
related:
    - "[Obsidian](https://obsidian.md)"
```base
formulas:
  ifRelated: if(related, related, "else")
  - type: table
    order:
      - file.name
      - related
      - formula.ifRelated
    sort:
      - property: formula.ifRelated
        direction: DESC
Yes.
The base properties “related” and “ifRelated” should have identical contents.
The “related” property shows a proper markdown link (Obsidian), but the “ifRelated” property shows that same link as a raw text string, not a link: [Obsidian](https://obsidian.md)
Obsidian version: 1.12.7
Installer version: 1.12.7
Operating system: Windows 10 Home 10.0.19045
Catalyst license: insider
Casting values to links via link() is not a viable solution (it just turns the string into a link to an uncreated note).
Workaround
For anyone in the same situation finding this thread via search: Resident bases help channel saint sailKite on the Obsidian Discord gave me this snippet:
if(related,
  related.map(
    link(
      value.replace(/^\[.*?\]\((.*?)\)$/, "$1"),
      value.replace(/^\[(.*?)\].*$/, "$1")
  "else"
