Bases grouping toggle to disable (low priority)
Once you group by a field, you can’t remove the grouping
  • we should click “group by this property” again to disable the group
  • once grouping is done, you can’t remove it from the UI
  • you can remove it through editing the base file as text and removing groupBy section
Obsidian version: v1.10.0
Installer version: v1.9.10
Operating system: Windows 11 Pro 10.0.26120
Catalyst license: insider
Insider build toggle: on
Community theme: Minimal v8.0.4
Plugins installed: 6
Plugins enabled: 6
1: Git v2.35.1
2: Omnisearch v1.27.2
3: Smart Connections v3.0.80
4: TaskNotes v3.24.5
5: Minimal Theme Settings v8.1.1
6: Mindmap NextGen v1.14.4
Image grabbed from another user as I’m on mobile, but does this help? (The trash can icon under the sort menu)
Thanks @ariehen
Apologies, I didn’t look group under sort, but this design looks perfect now. Thanks for pointing.
