Bases: filter to match all notes that have properties with empty values?
I’d like to create a filter that would show all notes that have empty property values. Excluding tags.
E.g. match a note with the following YAML:
tags:
hello:
But don’t match:
tags:
hello: there
Ideally, I wouldn’t need to write out each possible property into a formula. Though I’m ready to do this if need be.
Uploaded the docs into ChatGPT and asked it for help—to no avail.
Ignoring tags for the moment, there’s a way to do All notes that contain a property, but it doesn’t have a value mentioned here:
https://forum.obsidian.md/t/bases-migration-quick-start-guide/101571#p-326077-query-all-in-note-with-a-specific-property-8
So, note.keys().contains("hello") and !hello || hello == null filters.
    filters:
      and:
        - note.keys().contains("hello")
        - "!hello || hello == null"
Hopefully that gets you started and others jump in with suggestions.
For frontmatter properties excluding tags, I think this filter does it:
note.values().filter(value.isEmpty()).length - if(note.keys().contains("tags") && tags.isEmpty(), 1, 0) > 0
Not sure it’s the most efficient, but it’s what came to mind. If you find a cleaner way or notice an occasion where that doesn’t work, I’d love to know about it! And I could try to fix it.
Alternatively, if typing out each property, you could do:
and:
  - hello.isEmpty()
Dawni, I only tested the first part of your filter, because I’m only interested in notes with empty properties. So I added the filter note.values().filter(value.isEmpty()). It works, but Bases returns error: “Failed to evaluate a filter: Cannot find function “isEmpty” on type Boolean”.
But, again, it still works.
Thanks for pointing that out! That actually means the filter misses some empty properties. To my understanding now that you’ve pointed out that error message:
When a note has a checkbox property with a value (either true or false but not null), my filter will reach that error and stop evaluating the note. If that same note has a different property that is empty, for example:
textCheckbox: false
aliases:
… then the filter might not “see” the empty property, and the note won’t show up in the results, even though we want it to.
I can’t immediately think of how to fix it wholesale—that is, without manually separating checkboxes from the other types of properties.
This is a case where a .type() function would be handy.
Well, v1.9.7 gives us a better solution. (Released right about the same time I posted the above, lol.) I think this covers Astrolupo’s situation with no error messages:
note.keys().length != note.values().filter(value != null).length
If you’re still cleaning your files, peeragetalkers, this looks like a cleaner solution:
note.values().filter(value == null).length - if((note.keys().contains("tags") && tags.isEmpty()), 1, 0) > 0
Thanks, dawni, this works perfectly, no error messages!
