- Add a string property with long value.
- Add
tags
property with several value. - Create a
base
view.
formulas:
Tags: join(", ", tags)
- type: table
order:
- file.name
- Name
- formula.Tags
- file.ctime
columnSize:
file.name: 198
property.Name: 204
formula.Tags: 172
Y
Expect that when the long string got cut off, it will show ...
- For default property like
file.Name
or formulas, long string will end with...
. - But for string property define in file property, it doesn’t end with
, just covered by the adjacent column.
Obsidian version: v1.9.1
Installer version: v1.8.9
Operating system: Darwin Kernel Version 24.5.0: Tue Apr 22 19:54:33 PDT 2025; root:xnu-11417.121.6~2/RELEASE_ARM64_T8122 24.5.0
Catalyst license: insider
Insider build toggle: on
