Bases column width for numbers
I have a bases with lot of columns, some of them are numbers and I want the bases to take minimal width space. I want column to be resized to content. It doesn’t seem to work on number column, as it always default to 200, except when for some reason there is a note with a text value. That note is then in a “Type mismatch” state.
When there is at least one note in that state, the bases column auto resize function (when you double click the divider) works fine, but it’s not when all notes have number for that property.
As stated, I have some bases that works fine, when they have one note with a type mismatch.
Auto sizing and double-click resizing for number columns is fixed in beta 1.13.0 (changelog entry).
Hang in there.
much much appreciated !
