- Create a new base
- Create a new note
- Add a callout to the note
- Embed the base inside of the callout
- Right click an entry in the base
Did you read and follow the Troubleshooting Guide ? [Yes]
Context menu shows as it would when the same is done directly in the base file.
Context menu is missing the icons.
Obsidian version: 1.14.4
Installer version: 1.13.7
Catalyst license: insider
Insider build toggle: on
Plugins installed: 0
Plugins enabled: 0
