Backslash with pipe on links (\|)
Okay… I hope I’m not the only one having this problem.
I have being using Obsidian for almost 1 year. 2 months ago I decided to publish some notes with digital garden plugin + GitHub and of course Vercel.
But I have being facing the fallowing problem the last 4 days:
Every time I push something on my GitHub.
The file name of my links receive a strange syntax.
relative_path+file_name\|file_name
and Vercel can’t handle the | and always give me an error
Example:
The computer language Java is an OOP language and bla bla bla…
if I check the source of the Text I get this:
The computer language Java is an [[OOP]] language and bla bla bla…
BUT on my GitHub I get this:
Computersprache, die [[02 - RESOURCES/Notes/OOP\|OOP]] benutzt oder einfacher gesagt eine Objektorientierte Computersprache.
(Yep… this is german :stuck_out_tongue:)
Here comes my question:
There is anyway to remove the \|OOP ?
Things I have tried:
Some days ago I started working with aliases on my Templater. Something like this:
aliases:
  • oop
  • OOP
and I even deleted it all because I thought it was the cause of the problem. But apparently it is NOT.
Obsidian Version: 1.6.5
OS: Windows 11 / Linux (arch 6.9.6)
Okay I found the problem… I had a templater like this:
tags:
  - netzwerk/ip/ipv4
dg-publish: true
links:
reference: "[[IP Address]]"
path: Notes
created: 2023-09-13 10:14
and for some reason Vercel does not support the reference: "[[IP Address]]" syntax. I just removed it from my templater and with a simple script I removed this line from all my notes.
