My job has many tasks. I want to know how many hours on average I spend on each type of task.
For each task, I open a note. For each of these notes, I put as a property the type of task I am working on. Within this note, I also added the “Super simple tracker”, where I mark the time worked. At the end of the task, I fill in the “Hours” property with how much was spent.
With the dataview, I was able to filter by a specific task and know exactly how much time I spent.
However, I can’t make a way to add these hours and make an average work in DataView. I can’t even add them together.
What i currently have is this:
TABLE class, hours, ID
FROM "004 Work"
WHERE class = "Protocol" and concluded
SORT file.name asc
It goes like this:
File2 | class | hours | ID |
Link | Protocol | 1 hour, 2 seconds | - |
Link | Protocol | 2 hours | |
What I’ve tried and failed is this:
TABLE sum(rows.hours)/length(rows.hours) as "avg hours"
FROM "004 Work"
SORT file.name asc
If you have another plugin or another way to do this, that is, to obtain an average of hours worked for a specific task, please tell me.
I ask for help!!!
