I am working on further optimizing of my templates by Templater and below my template for the capture of a phonecall. So far I have been able to compile the desired filename based on various variables, including selecting the person from a folder (each person in my PKM has his own note) and after completing, moving the note to a specific folder (Events). Because all the contacts in my PKM start with “”, this emoticon is also included in the filename. I would like to keep the contacts to start with this emoticon, because all the subfolders in the “3. Sources”-folder starts with an emoticon (organizations, books, movies, ideas, etc.).
Example of the outcome of the file name of this template: “230122 phonecall Jon Doe plan road trip”
Now I would like to do a file rename via Templater (when making the note), where the new file name is the same as above, but without an emoticon. Then an Templater-action must be performed that removes the emoticon from the file name, without changing the other data. Due to my structure of the Templater-template (see below), the emoticon is always in the same spot in the file name.
Phonecall.md (534 Bytes)
I’ve already tried with the syntaxes “tp.file.title.split” and also with “tp.file.title.slice”, based on the following pages:
- https://www.redgregory.com/obsidian-content/2021/11/17/15-temlater-commands-for-obsidian
- https://www.reddit.com/r/ObsidianMD/comments/xg01is/how_to_split_a_string_backwards_instead_of/
- https://github.com/SilentVoid13/Temlater/issues/264 en
- tp.file - Templater)
With all my attempts I’m getting only parsing errors. I think it should be technically possible, using multiple variables (?). But with my experience in programming and logic, I can’t get it done by myself. Who wants/can help me further?
