Automatic image and attachment management (note-level attachment management)
@greatqs Hi! No, I don’t know of such a solution. Unfortunately.
I think an obsidian native solution for moving attachments with notes would be really useful for a large group of users. The solution by @dy-sh is intelligent, but you also have to give up some Obsidian smartness.
It would be a great addition to Obsidian if a note could be moved to another folder and the attachments would keep their same relative position. In my case, I store attachments in an ‘assets’ subfolder of the folder in which the note resides. It would be great if, when I move a note to another folder, its attachments would move with it to the assets folders of that new folder.
would also love this feature
Z
This would be a really useful feature.
My note-taking is rather image heavy, so moving notes with lots of images, say from an inbox folder to its permanent filed location, can be quite tedious and error prone.
Often, I will quickly make a note in a default folder with the hotkey, add some text and images, then move the note to its propper location with the “Move current file to another folder” in the command palette.
It would be very useful if there was a second command in the palette, lets say “Move current file to another folder, and bring all linked images also in the same folder/attachment folder with it”.
The key here would be to avoid moving any attachments that are linked in that are already in their correct location in a different folder.
+1 Follow
My use case: we share a knowledge base in our team using git. Most notes start out in a private folder, until they’re mature enough to be shared (i.e. moved to the general folder).
Most of our notes are using a number of images, which are automatically stored under an “attachments” subfolder of the current directory.
We want to be able to easily move notes/folders around in the vault, while keeping them portable as a unit (i.e. images are shared with the note when you e.g. zip a folder and send it to someone).
Currently we can easily move the “attachments” folder with the notes we move.
However, when there is e.g. 4 notes in a folder with images, and we want to move 1 note with its images. We need to start figuring out which images belong to which note.
Having 1 subfolder per note is not an option, that’s too cluttered.
In the meantime I will check out @friendlmickle 's suggestion (obsidian-consistent-attachments-and-links)
I think the plugin could do the following:
  • When moving a note, the setting 'Default location for new attachments` is honored, moving the attachments and creating a host directory if necessary.
If other notes point to the same attachments
A Modal is shown to confirm moving the attachments:
Do you also want to move the (5) attachments?
There are currently (2) links pointing to the attachments.
Don’t ask again [Move][Cancel]
I would personally click on don’t ask again.
Apple notes does this and it’s very confusing. If you drop a file or folder into a note it embeds it into the note (instead of linking to it). It’s one of the reasons I stopped using Apple Notes (along with it deleting two weeks of notes in an iCloud bug)
obsidian-attachment-management can be used as an alternative consistent-attachments-and-links (buggy)
This iS an old post, I know, but it’s still an ongoing requirement currently not handled in Obsidian natively.
To answer your question “why would attachments belonging to a note have a dedicated folder sitting along the note file”.
Because I don’t mind it, it help with my paranoia of notes getting lost because Obsidian seems to me (coming from Evernote) as a fragile geeky swiss-nife plain-text notes on steroids.
Anyhow, the IMPORTER plugin does exactly this - imports Evernote notes and puts attachments for each individual note from Evernote in a dedicated folder with the name matching the note name. So this is matter of consistency.
What am I supposed to do now? If I select any of the 3 only options available to manage attachments, it is going to be inconsistent with the original import.
To be honest, the only reason I went down into the rabbit hole of this hole thing is because I read somewhere - deleting notes will not remove attachments from the database… BAAM! … I need a plugin, do I trust it, what about if things run bad with REMOTELY SAVE and doing things from Android or iPhone, who knows what may happen, so I realized where am I going to look if there are issues that need manual fixing if things break. If I need to do that, where am I going to look for it.
So that is how that whole trip started for me.
I was looking for a smooth Evernote transition, which I got, import worked fine. And I could just carry on start using Obsidian without understanding how it works and later end with a mess like some people do when attempting to move manually attachments between folders.
Whatever the solution is, for a user coming from Evernote, I would expect:
  1. smooth experience (I move note and the rest is taken care of including attachments in the background)
  2. be able to manually navigate to the folder on the desktop (Finder, Explorer) with files and attachments and be able to see my markdown file there along with the attachments there nicely together. That gives me peace to my paranoia of having my notes safe.
I am more of that hierarchical approach for knowledge/reference management persona.
But I could also live with the fluid note-focused approach for Zettelkasten-style knowledge development persona if:
  1. all of attachments are consistent (so the IMPORTER plugin should also provide the choice of importing the attachment into the database with the expectation I am the Zettelkasten persona)
  2. All attachments should have the option to be auto-renamed so that their name includes the note name. This will allow the attachments to be sorted and found when looking for them manually in Finder / Exporer on Desktop.
I came from Evernote and I split my notes between Joplin and Obsidian since I want to run 2 separate databases for privacy reasons on different sets of computers and devices.
For me Joplin experience so far has been great, except for the PDF loading slower on notes and the sync being slower when using my own Dropbox/OneDrive (and not Joplin server). Obsedian is faster and renders PDFs well, sync is fast, but this attachment management got me off the track a bit. Still trying to figure out how to set it up. Because, to me it seems, once a choice is made, it’s hard to change later on and the plugins may not solve the mess.
How how I was struggling, you can see here, I had to consult ChatGPT to get my head around all the plugins:
And yet there seem to be a few more plugins now I am looking at like Attachment Management and Custom Attachment Location :exploding_head:
Okay I have finally sorted things out with my Evernote import and the attachment chaos.
Here is my summary of notes and recommended addons for users coming from Evernote:
It’s really surprising that such obvious feature is still missing. Obsidian is much more than just notes and with many plugins a lot of meta-information could have been stored as attachments…
However without proper attachments handling as part of a note it’s not possible.
I’ve used to use GitHub - dy-sh/obsidian-consistent-attachments-and-links: Obsidian plugin. Move note with attachments. plugin. However this plugin become in last versions quite unstable, so that I had to switch it off in order not to lose my attachments. And this is the clear sign that such must-have features cannot be in community plugins, it belongs clearly to core.
Dear Obsidian team, please make it happen - implement attachment management in core Obsidian!
thanks for sharing. I once lost data and a lot of my time for recovery. Since, no longer use plugins that handle files so massively.
I really hope this feature will be created one day.
