Autocomplete for callout types
When using callouts it would be nice if the supported callout types were shown in an autocomplete dropdown list.
As I start typing the callout syntax (eg. > [!) an autocomplete dropdown would show up, allowing me to select one of the supported callout types (note, abstract, etc)
While it doesn’t appear to work for inline autocomplete while typing, the admonition plugin’s ‘insert callout’ feature opens a modal that allows selecting the admonition type from a drop down list:
In contrast, Obsidian’s default ‘insert callout’ only inserts the following static text:
> [!NOTE] Title
> Contents
I searched the forum but didn’t come across any threads that seemed relevant to link here for autocompleting callouts, but these threads relate to autocomplete of other things:
I’ve also raised this on the admonition plugin’s GitHub repo as a potential enhancement/addition that could be made within the plugin if it’s not added to Obsidian core:
Edit: Turns out the admonition plugin already supports this!
Admonition offers this. I wish that the baked-in callout feature would offer a suggester of completion options!!!
