Not sure if this is a bug:
Within the YAMLl front matter the tag suggestion does not auto-suggest previous used tags within square brackets.
Tags suggestions are presented if the “#” used as a prefix outside the brackets. tags: #tag1, #tag2 However does not provide suggestions with either style within square brackets. i.e. tags: [ tag1, tag2 ] OR tags: [ #tag1, #tag2 ]
When typing the above tag, the name are not suggested to the user.
- Create a file with new tags: Crate a new tag “tag1”. Either use the front matter version “with OR without # prefix” OR outside the front matter using the prefix #.
- Create a second note that includes a front matter.
- Input
tags: [ <Tag from above> ] within the front matter.
UI should suggest previous used tags in a context menu pop-up
No suggestion was provided by the UI
- Operating system: Windows 10
Inputting the tag with the “#” prefix does provide suggested tag names within the front matter. However, only without inputing in a square brackets. tags: #tag1 #tag2
