It is extremely helpful that the new rename block ID feature renames all the references to the block when the command is run, but it still requires that you manually change the block ID afterwards, so that all those renamed block references actually have a matching block to point to.
It would be a lot easier if you could just right click on a block ID, choose “Rename this block ID…”, adjust the name in the dialog, click “Done”, and have both the references and the actual block ID renamed. I feel like there is a chance I may be misunderstanding the intended workflow. If so, I’m sorry.
Thanks very much!
