Auto conversion to link doesn't work for URL without TLD in preview
Type any valid URL that doesn’t include a TLD (excepting IP addresses - those work fine). It’s formatting in edit mode changes to show it is understood to be a URL.
URL is clickable in preview mode
URL is plain text in preview mode
  • Operating system: Win10
  • Obsidian version: 8.0.14
Confirmed on 0.8.15, Windows 10.
as a workaroud, you can always use markdown links [page](http://internalserver/page)
That’s what I’ve been doing as a workaround. Just thought I’d bring it up as a bug because the of the difference in behavior in editor and in preview recognizing the link.
I’m not totally sure if this is a bug or by design, but local hyperlinks (or any hyperlink with no dot in the server address) are not converted into clickable links.
Write the following addresses in a markdown document: http://example.com/ and http://localhost/. Then open the document in the viewer.
You see both URLs, but only the one to example.com is clickable.
Both URLs would be expected to be clickable.
Ironically, in the editor, both URLs are underlined and can be ctrl-clicked to open in an external webbrowser. Also, the link http://www.localhost/ does become clickable…
  • Obsidian version: 0.9.10
you can always use [localhost](http://localhost/)
