when you have an audio file/mp3 embedded in the notes and you scroll past it, it stops playing. I dont know if its a bug but ill keep the assumption that it isn’t.
Could you make a feature where the audio continues to play but it stays on screen? Like if you were to scroll down past it it would be visible at the top of the page, then when you pause it, it disappears.
I also want to ask for an audio queue (and also then controls to skip forwards or backwards if you had the queue enabled)
(EDIT disregard the above paragraph bc i may’ve found a way to do this myself from another post sorry)
my current workaround is to have a second window or tab under my notes file so it can continue to play but I’d just prefer if the file was already connected to the notes.
I figure i should mention that I’m requesting this bc im making notes on a podcast and need to read the transcript as well as read the audio to make notes on things so this feature would be really helpful for me.
Thanks so much regardless, obsidian is really good for my podcast note taking and many other things so good job : D
