Android URI protocol does not create notes if a different vault is open
  1. Have more than one vault in the Obsidian Android app (e.g. Vault1 and Vault2)
  2. Open Vault1 in the app
  3. Open the URI obsidian://new?vault=Vault2 (Obsidian URI - Obsidian Help)
The Obsidian app opens Vault2 but does not create a new note. Now that Vault2 is open, opening the same URI obsidian://new?vault=Vault2 works correctly. But then opening a Vault1 URI to create a new note does not.
Yes, as this is an Android bug there is no sandbox vault. I have disabled all plugins.
Opening the URI obsidian://new?vault=Vault2 should create a new note in Vault2
It does not create a new note in Vault2 if another vault is open. It only opens Vault2.
	Operating system: android 14 (Google Pixel 7 Pro)
	Obsidian version: 1.4.16 (114)
	API version: v1.4.16
	Legacy editor: off
	Community theme: Things v2.0.0
	Snippets enabled: 1
