Android text menu TTS and other standard menu options
We strongly recommend you to search the forum with possible keywords before making a new feature request. If your request is very similar to an existing one, consider liking it and/or making a comment rather than making a new one. Once you’ve searched and determined that this is a new request, delete this line.
Use case
The Obsidian Android app has made a lot of good strides in improvement, but the text editor doesn’t have some of the basic text features in the long press menu as pretty much every other app has. Some apps add to this menu (like Anki) but it doesn’t work in OB. There is also the system TTS which will read any text you long press, but not in Obsidian. It seems like these basic system features should be readily available in the Android app.
Make the long press menu to utilize system features.
Couldn’t find anything related to this…
