Android: Drag and Drop heading in outline panel stop working randomly
  1. In Android, start a new vault.
  2. Add a note and put three headings.
  3. Open the Outline Panel.
  4. Drag and a drop a heading
  5. Close the Outline panel
  6. Open the Outline panel again
  7. Try to drag and drop the heading. This time doesn’t work.
  8. Restart the app and it repeat the same issue.
Yes
The drag and drop heading in the Outline Panel should work every time you activate it.
Operating system: android 15 (Google Pixel 8 Pro)
Obsidian version: 1.8.9 (195)
API version: v1.8.9
Ever since the big update from v1.6.x, the drag and drop heading in the Outline Panel doesn’t work most of the time. It will work one or two times when you restart Obsidian. There are other time it stop working all together until I reset my phone. It’s a random behavior.
On Pixel 8 Pro phone running Android 15, I tried all the webview version 130.xx, 131.xx, 132.xx and 133.xx. All have the similar issue.
This also happen on another Android phone too.
Here is video showing what happening.
YouTube Short 2
YouTube Short 1
I tried on my Pixel and it works fine.
