Are you using iOS or Android?
[ ] iOS
[X] Android
Is this a bug report or a feature request?
[ ] Bug report
[X] Feature request
  • Create new note
  • Edit note title
  • Press return on keyboard
It would be nice when the cursor jumps into first line for editing the note.
If you’re using GBoard, unfortunately this is due to a bug with GBoard not sending us the “ENTER” key event, causing Obsidian to not know that you pressed the return key on the keyboard. Will get around to a workaround but probably much later.
Thanks for your feedback. Yes, I’m using GBoard. Didn’t know about this issue.
So it’s absolutely fine to set this low priority, if GBoard is the reason for this.
