Iām mostly in agreement with youājust trying to think through why this isnāt already built in.
Hereās the scenario Iām imagining: say youāre working on Meganote, which contains a dozen top-level headings. You need to write the sixth section, but that requires referencing info in sections 1, 2, and 4.
So: you have an edit pane focused on Meganote section 6, three preview panes with sections 1, 2, and 4. You donāt want to open a linked preview pane for Meganote section 6 because thatād be way too many headings.
You are editing away in section 6, and the handy new āremember where I was in Edit modeā feature is helping you flicker between edit and preview with reckless abandon.
But then you notice that thereās a minor issue in section 1 you need to edit. You select that pane, switch to edit, fix it, and switch back. How does Obsidian know where to āsyncā the scroll position for this pane, versus your other pane focused on section 6?
I suppose the app could cache the current scroll position of every paneās edit and preview mode, independent of the note, and use that information to keep things aligned⦠I donāt know enough about the finer aspects, either, to comment on whether thatās easy or not. But I guess my overall point is that this may not be easy.
Either way, though, I think itād be a valuable improvement in the app editing experience.
Iām afraid I know no more than you on this front!
