How to “escape” automation?
I’m a bit of a keyboard jockey but I believe EVERYONE would appreciate a simple solution like this…
When you type a quote, Obsidian gives you two and puts the cursor in the middle. This is great. Awesome, even. Same thing for brackets, parens, etc. BUT, how to you “key out” of them?
In Roam, you can TAB out of them but i can’t figure out how to quickly “get to the other side” with one stroke; other than typing the same sign again…which defeats the purpose of the automation if you ask me.
The TAB button doesn’t HAVE to indent a line if you are already in the middle of an automation like brackets, etc. Does it? You hit the TAB to get out of the brackets, quotes, etc. and then you hit the tab again to indent. This seems easy.
Can we take a vote??
