Obsidian uses “—” to separate slides. It breaks the outline of MD preview pages.
Instead of “—”, somethign like “%% — %%” might be used to separate slides without affecting the outline of MD preview pages.
I have the Smart Typography plugin along with the core “Slides” plugin enabled and had an issue with this as well. I found that pressing the - hyphen button 4 times instead of 3 times enabled separating slides.
