Allow unique note creator to use fixed timezone (e.g. utc)
I travel often and as a result my timezone changes all the time. Obsidian unique note creator is great, but because of the fact that it uses local time rather than a fixed timezone, I can never know the actual time at which a note was created based on the filename because it does not have any timezone information inside. Furthermore this causes problems with sorting because often times files created “later” would end up becoming “earlier” sorted if I changed timezone (e.g. fly west).
I would really like the unique note creator (and any kind of dated notes for that matter to be able to use a fixed timezone rather than local timezone)
The Calendar community plugin has a setting to override your locale which may get you what you want (but I think it’ll affect all of your template time stuff, not just Unique Note).
