I use pdf slides from school, and i need to be able to select and copy text from pdf documents. This doesn’t work in obsidians pdf viewer, for some reason. So I’m forced to open pdf in browser instead of using the smart pdf viewer. Fixing this would really optimize my workflow, as i can then work with multiple panels.
Fix or allow copying selected text from the pdf viewer.
Current workaround
Opening in browser, not optimal. Right click “open in default app” is most convenient way to do this.
