When using nocite elements in the YAML block, aliases are not detected:
e.g.:
alias: "yxc"
nocite: |
	@rosenbergerHardProblemPostPhenomenology2020
Here is the Pandoc documentation for the corresponding attribute: https://pandoc.org/MANUAL.html#including-uncited-items-in-the-bibliography
Either
  1. Recognize the nocite elements as YAML attributes or
  2. Recognize aliases independently of other YAML attributes
There is no problem with nocite. I believe your YAML is not properly formatted.
Thank you for your fast reply. Did you test the YAML I posted?
I did, it’s not correctly formatted because you used a tab instead of spaces.
