After running obsidian.exe, the graphical interface does not appear
In the windows operating system, double-click obsidian.exe or run obsidian.exe as an administrator
The obsidian graphical interface appears
The obsidian GUI does not appear.However, three obsidian processes will temporarily appear in the process list for a very short time, and soon those three processes will disappear.
windows operating system version:22621.1702
(1) Joplin had the same problem.
(2) Before this problem occurred, I had installed Evernote (Chinese version), which has been uninstalled now.
(3) I have tried to reinstall obsidian many times.
(4) This situation has not occurred in other applications
I see some contradiction here… :thinking:
If the problem used to occur for Joplin as well, then it is quite unlikely to be an obsidian bug…
Moved to Help because it’s unlikely to be a bug.
Were you able to use Obsidian before, or has it done this since you first installed it?
I don’t know what that Windows version number means. If you’re on a version of Windows that Microsoft no longer supports (like Windows 7 or Windows 8), Obsidian won’t run anymore.
