After import (Evernote > Yarle > Obsidian), some images not shown
What I did
  • Export notes from the Evernote application on OSX
  • Process notes using the Yarle program
  • Drag the output folders to my vault
Result
It all looked good, notes were there, tags were OK, etc.
…However
Some images are not shown, instead I see something like this:
Or in edit mode:
The strange thing is that this file exists, in the right folder:
Also, this happens only in some notes, other imported notes show the images just fine. The same goes for embedded PDF’s, at least most of them show up fine
I know…
…similar issues can be found in this forum, but I’ve yet to find a solution. And most are slightly different to mine.
Any ideas?
Have you tried running the ‘Check vault consistent’ command in the Consistent attachments and links plugin? This will give you a full report of the status of all links and may help identify the problem.
Also what version of Yarle did you use?
Thanks for that, I didn’t know this plugin yet. Works a treat and really helps.
And I used the lastest Yarle version, fresh download, on Ubuntu
