- Create new document and type in block of markdown preformatted text (use a pair of triple backticks on separate lines)
- Paste at least 4000 of lines
consisting each of a single URL length t least 43 symbols, space and symbol Xbetween triple backticks pair. (I first used sample youtube url, but got an error, thus textual description) - Put cursor in the end of last URL line and start typing anything
Did you read and follow the Troubleshooting Guide ? [Yes/No]
No. This is clearly a bug.
Editor behaves the same as when there are small (say two) number of lines in a pair of triple backticks.
Whole editor blinks briefly displaying all URLs formatted.
Obsidian version: 1.13.7
Installer version: 1.8.9
Plugins installed: 1
Plugins enabled: 1
1: Image Converter v1.4.3
The use case is I store a plain text list of URLs and other lines and I mark them with X if this URL has been processed (whatever that means). I don’t use actual lists because some items contain letters that are interpreted as markdown and escaping them inline is a bother. Also this way URLs are formatted as clickable URLs as only every other one.
