I’ve only been using Obsidian for a few days, but I’m hoping I can explain my use case and you might be able to recommend a path forward.
I have a bunch of unfinished music projects that I have made in Reaper, and I’m moving away from its built-in project management system. I’ve decided to overlay an Obsidian vault over my existing folder structure. Each project has its own folder, so the recorded audio stays with the project itself. I installed Folder Notes so clicking on each project folder brings up the notes for that project.
Every project has the following data:
- Title (this might be different than the folder name, because sometimes the song evolves from a working title to the final one);
- Album
- “Artist” (in actuality, I’m the artist on all of them but this is how I keep my styles separate—e.g. electronic dance music vs AOR guitar music).
From here, I have to-do items for each project, categorized like so:
Audio
- Mic In
- Line In
- Comp
MIDI
- In
- Comp
General
- Mix
- Write
- Arrange
So for a given song, under Audio > Mic In, it might say:
- Re-record claps
- Record triangle
The idea here is that I can look at the notes for a song and I can see what still needs to be done. It helps to have them organized this way because I often have to be in the right zone to record, say, conga drums, and if I’m going to drag them out, tune, them, mic them up, and realize I’m on a roll, then I might as well lay down the missing conga parts for all the tracks that need them.
So: I’m looking for a way to add this kind of data to each project, so that when I open the note for that project I can see everything that’s left to do, and also, there’s a way to list out every song that “needs bongos” or “needs bassline”. I could filter by “needs bassline” and it would show me all the songs that need one, organized by “Artist” and then Album.
This seems like the kind of thing Obsidian can do, and I have installed DataView thinking I might need this, but I haven’t figured it out yet. Any push in the right direction would be much appreciated.
