Hi, is there any way to embed audio or video directly without resorting to iframes ?
I use iframes for youtube / vimeo videos and video / audio tags for local files.
Do you have problems with the iframe approach?
First off, happy holidays!
Today is a great day! After fixing a lot of bugs in the last few weeks, i’ve decided to release the first major version of advanced slides.
Features:
  • Embed your notes into your slides
  • Live Preview while editing your slides
  • Themes allow you to change the appearance of your slides
  • Annotations allow you to change the style of your slides
  • Full support of the Obsidian Markdown Syntax
Ontop there is a present for all of you:
:tada: Grid Layout
It was never easier to arrange the layout of slides!
:santa:t4:Merry Christmas :christmas_tree:
Thank u very much for this Christmas gift! I’m very grateful for the progress of this plugin. I would like to know if you have the possibility to execute js code blocks for example from Admonition, Jupyter, Plotly, Dataview?. If not, I think it would be a tremendous advance for those of us who work with data presentation.
Hi, me again hehe. I have another question: How can I change the font size of a very large markdown table to fit the slide? Thank you very much and sorry to bother you all the time.
The easiest way would be to annotate the table with a font size like this:
<!-- .element: style="font-size: 12px" -->
First Header | Second Header
Content from cell 1 | Content from cell 2
Content in the first column | Content in the second column
Hi @MSzturc , I want to report a potential bug with markdown tables: You see in the rendered table, there are extra prime ` symbols beside $\sigma$ and $\xi$. Not sure where they come from.
test |$\sigma$ | $\lambda$ | $\nu$ |$\xi$
value |  0 |  0  | 0   | 0
Nice find, will be fixed in the next release
Today, Advanced Slides was accepted as community plugin. Hooray :partying_face:
No problem with iframes, but I just wasn’t aware I could put html audio / video tags right into Obsidian for local files. Thanks !
Thanks alot for this wonderful plugin. Did some testing around (while trying your demo-code) and researched a bit about how to set those up on github pages.
Nothing fancy for now, as i was just building the workflow - but here is the working main-hub for my presentations: https://abhuva.github.io/
So easy to share with QR-Codes and watch on phones now, this will defintly improve the quality of my lectures/presentations by a ton.
Wonderful christmas present !!!
Thanks for sharing your presentations! The demo template looks so good and really ups the game with this plugin. Would you be open to sharing it at some point?
Its not mine, i just learned from it. You can see the full source here:
Today I released version 1.5.0. With this version, Advanced Slides also supports reveal.js plugins.
:high_brightness: Highlights
:rocket: Features
  • feature: added Chalkboard to slides
  • feature: added menu plugin
  • feature: added default theme property to settings (#25)
  • feature: added transition style setting (#25)
  • feature: added highlight theme configuration to settings
  • feature: added configutation of controls plugin to settings
  • feature: added progress bar configuration to settings
  • feature: added configuration of transiton speed to settings
  • feature: added icons (based on font awesome 5)
  • feature: added autoClosing html tags
:bug: Fixes
  • bugfix: controls color should not be overwritten by autofont color
  • bugfix: slides where not rendered properly when the were in a subfolder of vault (#33)
  • fix: icon comments where ignored
  • bugfix: codeblocked image where not rendered properly
:books: Documentation
  • docs: added documentation for overview plugin
  • docs: added documentation for chalkboard plugin
  • docs: added documentation for menu plugin
  • docs: added documentation on Icons
:round_pushpin: Other
  • build: detect scss & template changes in watch mode
Many thanks for your GREAT works! It really saves a lot of effort in writing slides. @MSzturc
Meanwhile, I often need to show or share slides where no obsidian installed, so will you please support HTML export feature (like marp for vscode) so that the slide can be shown without obsidian enviroment?
I think it would be very useful for slide authors and audiences.
Thanks again.
This is already possible. When in live preview. Klick on the more Menu (3 dots) and then Export as html
Regarding the new plugin functionality (wich is awsome) - how do i enable them? I searched the docs, but i didnt find a breakdown how to configure them.
Especially regarding the menu-plugin, as this normally have all the options to include custom entries etc - wich are done in the html.
Or did i misunderstood it, and i still have to finetune it in the html?
Thanks for any pointers, as i was eagerly awaiting this change.
Wonderful :+1:
I find a problem with unordered list, which is as follows,
I write these codes in obsidian,
##### **test 02 - Fragmented Unordered list**
- Permanent
+ First
    test1
    ![](upload://ux8PTvS1L19rEp1ZFrkH2rN737H.jpeg)
+ Second
and then i get output like this from the plugin, it seems text ‘test1’ doesn’t take new line under ‘First’, also the picture doesn’t align correctly. Please confirm, thank you @MSzturc
The expected result should be like this, FYI.
  • Permanent
  • First
    test1
  • Second
@MSzturc
Where in the docs do i find how to enable the plugins (like menu), and how to configure them.
Especially regarding the menu-plugin. I know from just using reveal.js, you finetune it in the html file what exactly to show and use custom links and menu-entries.
Is this possible already in your plugin?
