Adjustment/removal for delays in context menu
Upon choosing format/paragraph/insert options in context menu there’s a rather long delay that seems to be intentional. It hurts fluidity of use.
Adding option in Editor settings to adjust this delay or completely remove it. I can’t see any value in it, it feels unresponsive and does not correct any user mistakes as far as I can imagine. But if there are reasons for it to be there, it can be a default setting.
Obsidian_JC0cIzeyjf
Your observation about the delay in the context menu is valid and can indeed affect the fluidity of use. Adding an option in the Editor settings to adjust or remove this delay would improve user experience. While the delay might be intended to reduce accidental selections, allowing users to customize it according to their preference would strike a balance between usability and error prevention. This customization would ensure responsiveness and adapt to individual user needs.
