I would like to hire someone to build this plugin. I want to confirm that it’s possible. If you want to work on this, please let me know. If this is already possible, I would appreciate that to!
Use Case
When I’m taking notes in Obsidian, I often want to add the same information to multiple places.
For example, if I’m taking a daily note, I may want to include the same block in the next days note so I can remember to follow up.
I know that Dataview is capable of doing this, but it’s a bit cumbersome, and you can’t edit the note.
Transclusion is also cumbersome, and would take more time than just copying and pasting the item in the next days note.
Proposal
When I add a tag to a paragraph, add the same text from that paragraph to other notes.
example: Remember this tomorrow #mike
Where to put it
Look for other notes in Obsidian that have a header that’s the same as a tag.
It would look for any header titled
Mike
It would place the paragraph in it with a link back to the original.
Ideally I could edit the text in either note and have it sync, but this isn’t 100% needed.
Time Boxing
If a header is formatted like this
Mike - 7d
Only copy in notes from the last 7 days. Any number of days can be added.
