This would mostly be helpful on mobile touchscreens, where there is currently only a back-delete command on soft keyboards.
Moving the insertion point immediately in front of the character that needs to be deleted is often slow and fiddly on mobile touchscreens.
Add a forward delete command to the command palette. It would ideal to also add a button to the stock mobile toolbar, but if necessary users can create their own with the Commander plugin once the command exists.
