When inserting an internal link to a canvas or base it should automatically insert default display text to omit the extension of the file. This used to be the case but has been removed.
For example inserting an internal link for [[Test Canvas.canvas]] should automatically update to [[Test Canvas.canvas|Test Canvas]] so that it displays as Test Canvas not Test Canvas.canvas in the document.
This feature previously existed and apparently was removed in 1.11 (despite not appearing in the changelog) according to these bug posts:
* https://forum.obsidian.md/t/when-linking-to-a-base-it-doesnt-set-a-display-name-like-linking-a-canvas-does/106745
* https://forum.obsidian.md/t/links-to-canvases-do-not-remove-the-extension-when-pressing-tab/110787
Perhaps it was accidentally changed in 1.11.5 which states:
Restored default display text when inserting a link with folders in the linktext (e.g.
[[a/b/file]]will automatically be inserted as[[a/b/file|file]]).
maybe this change broke it for .canvas and .base files?
The internal link should autocomplete and set the display text to the name of the canvas without the extension. This used to happen correctly and was removed in a recent version.
Manually typing the display text (though this is very tedious for long named files, especially when this automatically happened in the past)
