Add an option to not maintain numbered lists numbers, keep «1.»
I use git to version my vault and it is annoying when I add only one item in a list and Obsidian renumbers everything so git sees many lines changed.
Add an option to enable/disable autonumbering of lists.
As a workaround you can turn off Settings > Editor > Smart indent lists. (But this may remove more functionality than you want it to.)
