Add ability to use keyboard controls for settings and F6 to switch between them
I like to use keyboard shortcuts where at all possible. I use Ctrl + , to get to settings/options, and usually this is quite nice as it remembers the category I was on previously, eg “Hotkeys.” However, when I want to switch from Hotkeys to, say, Appearance, I’m not finding a readily available way to do that via keyboard inputs.
Most programs use F6 to switch between “Main elements” and tab to switch between elements within a window. This is an accessibility standard, so improving this would improve Obsidian’s accessibility grade :slight_smile:
Make it so that there is a hotkey for switching between main elements/panes of the user interface AND be be able to use the arrow keys (or even wasd/asdf if you’re cool) to go up and down or into a given element of the options interface. For even more points, add hotkeys that go directly to these (although I admit that might clutter the hotkeys, but let’s admit it they’re pretty cluttered as it is and that’s a good thing)
For more information about the industry standard, this is the AI Overview from searching “F6 Main element”:
In many applications, pressing F6 (and Shift+F6) is a common accessibility shortcut used to cycle between main elements or panes of the user interface, such as the document, ribbon, status bar, and task pane.
Here’s a more detailed explanation:
Purpose:
The F6 key, and Shift+F6, is designed to allow keyboard users to efficiently navigate between different sections or panes of a program’s interface without having to tab through potentially numerous controls.
How it works:
Pressing F6 moves the focus to the next main element or pane in a defined order.
Pressing Shift+F6 moves the focus to the previous main element or pane in the reverse order.
Examples:
Microsoft Office (Word, Excel, PowerPoint, etc.): F6 can cycle between the document, ribbon, status bar, and task pane (or split panes in a document).
Microsoft Edge: F6 cycles through the address bar, bookmark bar, tab bar, and content panel.
Outlook: F6 cycles through the message list, status bar, ribbon tabs, navigation bar, and folder pane.
File Explorer: F6 can be used to move focus to the content pane, which lists folders and files.
Accessibility Insights for Windows:
F6 and Shift+F6 are used to move between UI Automation Tree elements (parent, sibling, child).
Must use mouse to click on desired main element of settings
They haven’t been posted but a related one would be to check and see if there are any other UI windows with “main elements” which could also use F6 to switch between them.
