so i just want to easily create note without opening obsidian on mobile. what i thought of was to put it in the notification like how when you receive a text message you can reply to it without opening the app itself
Because Obsidian notes are just text files, you could use a separate app if you find one that has this feature and can save to .md files in your vault folder.
