Add a not synced or not downloaded button when attachemnt is not synced
Currently if one chooses to not sync attachments (PDFs for example) on mobile the embed will just show up as a file not created. If I accidentally click that it starts making empty files with the filename as a title. It also looks ugly.
I would like you to differentiate between the actual non-existent and non-synced attachments. That would probably require a full file list where it would look up if the file is in the file list but not synced in the vault it would write under that file file not downloaded or something like that.
This was changed in 1.5.3
You’re right it is in the release notes. But I have just went and checked and it doesn’t work for me. At least not on video and pdf files.
